1 - 2 of 2 Posts
I have a blue colored line through the right of my screen to the middle of the left. I also have a double image below the line that makes the image look 3D. I've been told I have a Convergence problem and need to have a Tech come look at it. I called and the cost is $200.00-$400.00. Is there any other options?
I was also told to try Degaussing the tv, but research on that looks like it would not help. Any Suggestions?
How about a model number. Whomever told you about degaussing a RPTV needs to do some research.
After you get the model number, get the service manual. If it is convergence, it should be easy to correct unless a component went south.
1 - 2 of 2 Posts
