Status
Not open for further replies.
1 - 2 of 2 Posts
Thanks to advice from several here I went out and bought this unit . I now have a Hughes E86 receiver hooked to the set. WHat should I do to tweak this TV and get my $$ worth from it. Please answer it newbie terms so I understand what you guys are telling me.
Thanks..
The first thing I think you should do is buy the Avia set-up disk. It's a DVD that has a bunch of test and color patterns on it that you can use to tweak your TV to look good.
1 - 2 of 2 Posts
Status
