1 - 2 of 2 Posts
I have a mitsubishi dlp tv. Recently after watching tv it will turn off automatically and the green light on the front will blink. Using the remote I used the code Menu+ 3564 and it lamp codes and whether or not an issue occurred. It listed code 34, lamp abnormality, does this mean I need to purchase a new lamp? I removed the old one which had alot of dust build up, didnt know if that may help. I cant find anything thru google that would help explain what a lamp abnormality is. Thanks in advance
From the manual
TV turned itself off and the light on the front panel started to blink.
• Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset.
• If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Also, there is a software upgrade available http://support.mitsubishi-tv.com/documents/WD-73C9
Good luck.
1 - 2 of 2 Posts
