1 - 3 of 3 Posts
I have a Mitsubishi HC1600 projector that i would like to hook up to and control through my Main Lobby Server. The projector has a serial port on the back but the manual says its for "technicians use" whatever that means. My question is does anyone know anything about this model? Will i be able to control it through the serial port? All i really need to do is send a power on and a power off command.
Thank you
1 - 3 of 3 Posts
