1 - 5 of 5 Posts
I have a WD-52525, I'm on my 3rd bulb within the last one being put in about 1 1/2/2 years ago. The picture is so dull and dark, can the bulb really be shot again? or is something bigger than that. I can't tell you how bad the picture is.. it's terrible to say the least!
I pretty sure I need another bulb, but I'm just annoyed that I need to do it again.
What's the best aftermarket bulb?
thanks
Pete
thanks
Pete
Always go Philips. I would not use anything else.
+1 Servicetech571
That is absolutely correct. I own a WD-52825 and live in a dusty environment (gravel road). I pull the screen and clean the mirrors twice a year. For a set that has never been cleaned, you will be amazed at the amount of dust on the lower mirror. Carefully clean the both mirrors as well as the lens on the light engine. Do not clean the back of your screen with anything except a swiffer type duster. After a good cleaning your set should look many times clearer and brighter. Good luck and take your time!
Discussion Starter · #5 ·
Thanks guys, yeah I had the tv cleaned about a year or so ago right after they replaced my chassis and right before I had the 3rd bulb put in. Hopefully that's not it, but I'll have to try to figure out how to clean them up. (is there any cleaning instructions?)
thanks
-P
1 - 5 of 5 Posts
