I have a WD-62725. I replaced the caps for the BGLOD fix. After assembling the chassis I got the steady red light for a short, four short one long error code on the front of the set. I finished assembling the chassis completely, plugged in the fans and turned the set on. It quit with the error of Chassis fan not working. I found I had the chassis fan plugged into the wrong connector, fixed that and turned the TV back on. Well I'll be damned! It worked.
It worked for 10 minutes and quit again.
I plug the TV in and get a Click and a solid red status light and code 41 for a short. My question is what should I check next? I disassembled the chassis and checked for pinched wires but I don't see anything. Just wondering if anyone could point me in the right direction and if not, my Mits Project will continue for a few more months. The bad thing is I know it works. I saw it working.
Have a great Holiday Season and Thanks in advance!
