I have build a HTPC and I have a Asus Geforce video card. Using Powerstirp I have been able to get 480P to input into the tv using the VGA connector.
Is it possible to get 1080i to input through this VGA input? If so, has anyone had any luck doing so? Or would I be better off getting an ATI card and using the component video breakout cable that is available?
Even at 480P I am pretty unhappy with the picture quality. Am I doing something wrong? What is the best resolution combination people are using?
I really only use CDJ from Nirvis right now...I hope eventually do more with my HTPC but I am still pretty much a newbe.
If anyone has any experience with this and if you have the powerstrip settings you are using.......it would be greatly appreaciated.
Thank you!
Thank you!
