Hi Greg,
Just to add a bit more detail to this story, by the way i live in Australia if you hadn't noticed, I complained very much to mitsubishi when i started seeing the verticle bar problem & at first i thought it was some sort of scan line problem.What happened next was really funny by annoying. They requested the unit back so they could test it.Ok, fair enough, no cost to me.When i finally rang them for some info,i was told they had checked it out using a computer through the d-plug input.Indiots. I proceeded to tell them that if they had read my note enclosed in the box it would have told them to use s-video & dvd material. Of course they replied that they could not see a problem.Don't know if they even tested it with the correct video input.
On return of the unit i was back on the phone to complain again as now there were purple patches all over the screen, someone had put fingerprints on the inside of the lens, including some dust patches.So back it went again.
On return again, i complained that the original vertical line problem was still there, so they agreed to come to my place & check it out. They brought with them 2 other models, the S50U & X70U. The x70 is xga res, while the s50 is svga.When comparing these 3 units against each other, we were all very surprised.My unit, the S250U WITH 1500 lumen brightness was the best performer. The vertical lines were very evident with both of the other 2 units, while mine was watchable, you had to look very closely.The other 2 units, the x70 being more expensive, did not handle the video signal anywhere near as well as my unit, this stunned everyone. I had 2 mitsub reps standing with no real explanation.
Well, that gives you a little bit of info. I still have my unit, well, not exactly, it's now back at the service center with lamp problems. The lamp would arc on startup & shut down right away. The lamp only had 1400 hours on it & just before this problem occurred, i noticed a very large downgrade in performance & brightness. Still waiting on a report from mitsub to also tell me if this is all under warranty as it is only 11 months old.
I must say though that when the unit it running, it runs very well.I just seem to be having a few small glitches & the people & reps who i have been dealing with sofar have been very helpful. I might just keep you informed with what happens with this unit.
Hope that gives everyone some info, really not sure what causes the vertical lines but it carries on through their whole line up of projectors, some handle it better than others.
cheers
Dean
