I looked around and found lots of information about combining antennas (and the associated pitfalls), but didn't see the specific answer to my issue.
I got a Square Shooter roof mounted with my dish a few weeks ago. For those that are not familiar with this antenna, it is supposedly UHF only (though I know the high end VHF come through often). Because of my unique terrain situation, the only channel I could get was on frequency 10 (VHF). I thought this was odd given it was a UHF antenna but since freq 10 was the local ABC affiliate and I had MNF, I didn't mind too much.
Just for kicks I tried a Silver Sensor indoors and was able to get some additional channels intermittently. I figured getting my SShooter higher on the roof and professionally placed would help things. After the move I can now get the local NBC affiliate (at frequency 35) and nothing else. This is great since I'd like to get ER and WW in HD, but I have now lost the freq 10 altogether - like "0." All this off-air stuff is so unpredictable, but I knew that going in.
My most recent idea is to add a small second, VHF only antenna via a common splitter (before the diplex) in an attempt to get freq 10 back. My question is this - will I have to worry about conflicting signals from a UHF only antenna and the VHF only antenna? As far as I understand it, while there is some overlap, there will not be enough (especially all the way into the 30s) to conflict with the UHF. I know others are using channel filters successfully, but if I don't need one, I'd rather not have one.
Any suggestions? If I could get NBC and ABC, I'd be fine until the Spaceway sats get into the air next year and eliminate the need for an antenna all together.
