1 - 4 of 4 Posts
· Registered
I am new to this site and am looking for help!!! setting up a hometheater bass system, have a nad t775hd amp which has 2 subwoofer outputs.Have got a psb sub which works fine, but am trying to incorperate 2 EV bass bins a furman crossover and a crown power amp that I have from my band days for additional bass.Have run a cable from the 2nd subwooer out on the nad but can't seem to get enough signal. the cable seems to be fine,but can't even get a signal when plugged directly into the crown power amp.Would appreciate any help!!.
· Banned
Originally Posted by Eyleron  /t/1518002/mixng-hometheater-gear-with-sound-reinforcement-equipment#post_24370422
I imagine Electro voice bass bins won't extend to the 20 Hz you'd want for home theater?
They probably won't do much below 40Hz, depending on which model they are.
· Banned
Sounds like your receiver doesn't have sufficient line level output (assume you tried switching your sub preouts around to make sure its not the connector on the receiver). This with full gain on your amp? Do you know what the receiver preout is rated for? I couldn't find it on the Nad site.
1 - 4 of 4 Posts
