Your probably pushing your laptop specs running 1080P to your Plasma.
Originally Posted by df1021 /forum/post/16823757
My cpu usage jumps to 80-90 % at full screen and 65% using the Windows Media Player skin. The files are x264 720p. If I was to use CoreAVC, do I uninstall the klite codec pack first? Thanks.
I would like to build my own htpc if someone could give me some ideas with a budget of $800. I already have Vista.
Originally Posted by df1021 /forum/post/16860069
I appreciate everyone's feedback. I have come to the conclusion that my laptop gets way too hot to handle h264 movies above 3 gig. My next step is to build a htpc. I want to start off with the Antec Fusion Remote Black as my case and build from a Intel / Nvidia motherboard with at least 2 tetrabytes of hard drive. I also want a solid bluray drive and hd tuner to hook up to an antenna. Though I had previously stated that I could spend around $800, I would like to spend only $500 total (less the operating system and peripheral equipment). All feedback is appreciated and I am willing to donate funds to anyone able to give me the necessary information to make my htpc usable to play any hd movie. This will be my first time building a computer and I understand some language, but I will need a lot of step by step information to build this from ground up. Thanks.
Price | |||
Case | IN WIN IW-BK623.BN300BL 0.6mm SECC Steel MicroATX | Newegg | 59.99 |
Mobo | ECS G31T-M(1.0) LGA 775 Intel G31 Micro ATX Intel | Newegg | 44.99 |
CPU | Intel Pentium E5200 Wolfdale 2.5GHz 2MB L2 Cache LGA 775 65W Dual-Core | Newegg | 69.99 |
RAM | WINTEC AMPX 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) | Newegg | 22.99 |
DVD-RW | HP DVD1160I Internal SATA Drive DVD+R 22x/DVD+RW 8x | Ebay(Tigerdirect) | 26.99 |
HDD | Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive | Newegg | 119.99 |
Keyboard | BTC 9019URFIII Black 87 Normal Keys 12 Function Keys USB RF Wireless Mini Multimedia Keyboard with Dual Mode Joystick Mouse | Newegg | 39.99 |
Remote | Microsoft Remote Control and Receiver for Media Center - A9O-00007 | ?? | 30.00 |
GPU | 256MB nVidia Geforce 7300LE TurboCache | From another PC | 70.00 |
Networking | GIGABYTE GN-WP01GS PCI Wireless Adapter | Newegg | 16.99 |
OS | Mythbuntu 9.04 | mythbuntu.com | Free! |
Total Cost | 501.92 |
