1 - 2 of 2 Posts
When I use the PS3 with HDMI to my PN58B650 I get the error message "mode not supported". The PS3 works fine with my PN42A450 through the HDMI and the 450 is only a 720P set. I can use the PS3 using component cables but output is only 1080i main purpose is to watch blu ray movies in 1080p.
I tried all 4 HDMI's
I tried different HDMI Cables
I set PS3 to automatic
I set PS3 to 480p
I set PS3 to 720p
I set PS3 to 1080i
I set PS3 to 1080p
I tried hand shake method
I hooked tv to internet and searched for latest update I have 1/05/2010 1017
I tried my friends PS3 60G same error code "mode not supported"
I used my laptop with HDMI and laptop picture was ok
This is not a isolated issue if you google "Mode Not Supported" you'll find numerous chats with people with the same issue using PS3, XBOX 360, PC's and Macs.
Is there a new firmware update coming soon!
Or has anyone found a fix?
if you have the games to autoload, insert a game and let it load. If you get picture then is something that has to do with the PS3 settings.
Sometimes the PS3 gets confused if you plug it on a 720p TV and then on another 1080p TV.
1 - 2 of 2 Posts
