Status
Not open for further replies.
1 - 3 of 3 Posts
I waht to buy a model B ( or C) without CSR, it will stay open all the time.
Even on the Da-Lite.com site, the difference between the Model B and C is unclear. I can only assume there is a black border all around the model C, but only on the side of the model B, by looking at the pictures.
The metal casing is bigger as seen on the spec sheet.
Could you confirm this or tell me the main difference?
The screen size can be special ordered on either. The difference is the case. The model C has a large "industrial strength" case the model B has a lighter "economy' case. If it will be open all the time, B is fine (or do like some and take it out of the case entirely). Mine is rolled 80% of the time. I have a C for that reason.
Discussion Starter · #3 ·
Thanks, model B is on the way!
1 - 3 of 3 Posts
Status
