Glad you like it. It's definitely more difficult dealing with a general living space vs. dedicated room, where you can hide all the "Big Black Boxes" (or just not care that much about how it looks).lol- As soon as i move into our new house im copying this as best I can lol ! Building 4 VBSS- but since ill have NO room for my theater other then the living room i want to keep it as nice as possible and this does it
Good luck on the builds!
Happy to hear that this build has you thinking about building your subwoofer, but you should start a new thread to pose any questions you may have.Hey smcmillan2 and all. Your blog has inspired me to get started.
I assume you're running the eq profile from the thread in your amp?I run the PA460 on one channel of an NX3000D, and the other channel drives the pair of sealed UM18s. Not nearly what the UMs would like to be fed, but it works out OK in the living room "HT" space.
I do not. Initially did before I introduced the UMs, but now have it setup to hit harder in the mid/upper bass regions. I really need to drag it outside and cut another hole in it to add the 2nd port to get to the native 31Hz tune.I assume you're running the eq profile from the thread in your amp?
Whats your tune right now?I do not. Initially did before I introduced the UMs, but now have it setup to hit harder in the mid/upper bass regions. I really need to drag it outside and cut another hole in it to add the 2nd port to get to the native 31Hz tune.
