Modular Wall Plate
2067 Views 2 Replies 2 Participants Last post by  kjr39
Hi,
I am wiring up my game room and can't find what I need. I would like a 2-gang modular face plate to hook up the following (but can't find it):
- 2 RG-6 Coax
- L/R surround
- L/R Zone 2
- 2 Cat 6
- 1 USB (can this be done?)
That's 13 plugs...
- For the USB, I would like to run a cable to the other side of the room in the attic that would allow me to connect my USB controllers to my 360. I have not seen this, so don't know if it is doable.
I've looked on monoprice and do not see anything that would fit...
See less See more
1 - 3 of 3 Posts
13 is an odd number. I have seen 6 "keystone" jacks for a single gang, so I am sure that they make a 12-jack double gang. Here ya go:
http://www.lanshack.com/Keystone-Flu...-P2372C56.aspx
For the jacks, I know Monoprice has some of the audio ones.
http://www.monoprice.com/products/su...04&cp_id=10426
For the USB keystone jacks and other keystone jacks you need, just google "USB keystone" and so forth.
FJ
1 - 3 of 3 Posts
