Status
Not open for further replies.
1 - 1 of 1 Posts
-I have a new Momitsu V880, latest firmware, and a JVC D-ILA G11
-I am outputting DVI to VGA to RGBHV. This allow me to output a 720P or 1080i image.
-1080i selected in the V880 menu outputs an image tht is about 1/6 too big for the screen (left-hand side is cut off some)
-I can select 720P in the V880, and then force the image to my G11 by selecting 720P instead of "Auto". This seems to display a correct-sized image.
-I want to use the custom DVI menu
-I used the tool from http://www.avsforum.com/avs-vb/showt...hreadid=330731 for custom res, took my powerstrip values for 1360X1024, but the image is too small, kind of 4X3 looking
-I also tried 1360 X 768, and the image is the correct shape (16X9), but is about 2/3 too small for the screen
-I also used the wizard and inputted my values, but again the size of the image is either too smal or 4X3 looking.
Any help greatly appreciated. I am a HTPC guy and never had any problems getting a perfect match with powerstip.
Jason
1 - 1 of 1 Posts
Status
