Hello,
My HTPC has been running for a while now with little to no problems (specs listed below). I recently built a home server running WHS 2011 and installed the connector on my HTPC. I'm not sure if it is related or not, but I used the HTPC in the morning and it was fine, but when my wife used it later that day, BSOD.
I was unable to resolve the problem, so I decided to reinstall Windows 7, but this time tried Win7 Ultimate 64bit instead of Win 7 Home 32bit that I used before. Everything installed fine (I had not installed the WHS connector yet) but when I used my Harmony One to play a movie, the remote didn't seem to work. I uninstalled the Moneual Labs included driver and software for M.Play MX then reinstalled and when I try to start the program it says 'File Not Found' followed by a message saying that it can't find something (it was a long file string with .jpg at the end I think) followed by 'File not found'. It shows that the M.Play MX icon is in the running programs in the bottom right tray, but the remote doesn't work. Also, I can't open the M.Play MX management program that allows me to change the settings for the LCD.
Thinking that I needed an updated program/drivers, I downloaded the latest from the Moneual Labs site, but still the same outcome. I then reinstalled Win7 Home 32bit edition so everything was back to how it was before I installed the WHS connector and I'm still getting the same result.
Any idea what could be happening? Everything else works perfectly, the LCD lights up with the MonCaso logo (but it doesn't cycle between the default screens of CPU temp, date, time, welcome message, etc), I checked the connections in the case and everything appears to be ok.
Very confused why the included software and driver isn't working. There aren't any errors during the installation either.
OS: Win 7 Home 32bit or Win 7 Ultimate 64bit
CPU: AMD Athlon II X2 240 Regor 2.8GHz 65W Dual-Core Processor
Mobo: GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX
RAM: OCZ Platinum 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333
OS HD: OCZ Vertex Series 30GB SSD
Media HD: Western Digital Caviar Green 500GB SATA
PSU: Antec EarthWatts Green EA-430D Green 430W 80 PLUS BRONZE Certified
GPU: SAPPHIRE Radeon HD 5570 1GB DDR3 Low Profile
Optical: LG UH10LS20 Blu-ray SATA 10x SuperMulti Blue LightScribe
Case: Moneual Labs MonCaso 312B
