1 - 1 of 1 Posts
Hi,
somehow I am mot getting the results from the replacement gsw12 I think I should get.
I have 2 issues: gsw output bearly audible and propper 12v trigger setup
the system is fully setup:
Onkyo 5008
2 x gs60 bi-amp
2 x gsfx
1 x gslcr
1 x gsw12
the gsw light is green. settings display is red.
settings on onkyo:
ohm are set to 6
speakers are set to
front 40 Hz
center 40 Hz
surround 40 Hz
LPF or LFE 100 Hz
sub level calibration at -1 dB
gsw settings unchanged. set to LFE.
at -24 dB the sub is barely audible, at 0 dB on gsw I get 62 dB output with spl using the onkyo test sound.
Do I need to raise the eq dB levels on the GSW first to make it work or should it work out of the box ?
would you have any idea whats causing this and how to isolate it.
2. Also I am using a malke 3.5 mm to male 3.5 mm stereo 12v trigger cable from the onkyp zone 2 to the gsw. How do I have to configure it so the onkyo turns on the GSw and also turns it off again ?
best regards
babbahotep
1 - 1 of 1 Posts
