You need to determine at what refresh rate you can't detect flicker. It varies from person to person, but VESA has set the flicker free standard at 85Hz. Some people can't detect flicker at 70Hz and some can detect it at 100Hz. Use your peripheral vision to check. Set your desktop to a low resolution running 60Hz refresh and increase the refresh until you can't see any flicker. This is your flicker free refresh rate. If the monitor in question will support the necessary resolution at your flicker free refresh, then it should be usable.
The evaluation of picture quality is for your eyes only. Also, consider the size, weight and power consumption.
Maximum resolution may be nice and high, but if you are always running [email protected] flicker free refresh rate, then it really doesn't matter that the monitor can run [email protected] flicker free refresh rate.
