Status
Not open for further replies.
1 - 5 of 5 Posts
Any chance the 100ft. run of the Monster Cable® ISAT™ 200 cable is any less efficent in transmnitting my UHF HD antenna signal than a Belden or other MATV/CATV cable would be?
Is there a possible signal loss whereby the Monster Cable® is only straded for long DSS runs?
Any thoughts
Murray Kerdman
"ISATâ„¢ 200 Direct Burial High Performance RG-6 Digital Satellite Cable
Monster Cable® High Quality Speaker, RF/Video, and DSS Satellite Cables with Jackets Approved for Direct Burial
Heavy gauge, low-loss precision 75 cable for high quality signal transmission. Superior shielding for protection against interference.
Heavy-duty, direct burial jacket can be run underground without putting in conduit. Withstands inclement weather and exposure to ultraviolet light.
A requirement for long DSS runs.
Available in long lengths for flexible placement of dish."
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Any properly made RG-6 will be fine for UHF/VHF.
"better living thru modern expensive electronics"
tm
Originally posted by mkerdman:
Any thoughts
Murray, Can not comment on the Monster cable (no specifications). As Ken said "Any properly made RG-6 will be fine for UHF/VHF". The cables from Alpha Wire, Belden, and CommScope will be Sweep Tested for proper operation.
Wendell
Technical Services Supervisor
MAETV
[This message has been edited by Wendell R. Breland (edited 04-28-2001).]
MC 200 should be fine. I've installed LOTS of it never had any bad experiences with it.
Dave
Watch HDTV!!! Nothing else comes close!
[This message has been edited by David Richardson (edited 04-28-2001).]
All I know is that using monster cable from my dish to my dss box was a major problem... could not receive at least ten dss stations. It took many hours and lots of dollars to realize it was the cable, and not the dish postioning.
1 - 5 of 5 Posts
Status
