1 - 1 of 1 Posts
Please can some one help me out?
On the Monster Power HTS 1700
Should the “Ground OK” Indicator be on or off which one tells you the Ground is OK
Should the “Wiring OK” Indicator be on or off, which one tells you the Wiring is OK
The manual does not tell you if it should be on or off!
Thank You
Paul
1 - 1 of 1 Posts
