I'm getting some sort of interference with the PS3 on my TV. Since hooking it up, I can get some white or gray lines that crawl up the screen slowly. Mostly it's hard to notice during watching programming, but when I do see it, it's very annoying, especially on an HD signal where I'm used to seeing perfect images.
There is also a detectible hum when the sound is off. . .
Is this the ground loop problem I've heard of? If so, what is the appropriate fix. I have a cable hook up that runs into a box, that is then connected to my TV via component cables. My PS3 is hooked up with an HDMI to DVI connection. . .but the lines were visible with a regular composit connection as well.
