When it locks up at the "checking for new software", is the modem on-hook or off-hook?
I found that mine would get stuck at this point after having dropped the phone connection. It seemed that it just ignored the loss of carrier. I got in the habit of checking every morning.
Switching to a different local access number made it happen less often but it did not go away completely.
When you reboot, do you hold down the power button, or unplug? I used to hold down the power button, but I think unplugging it might work better.
Also, have you tried forcing a lower modem speed?
I temporarily switched to network but would rather switch back to modem (odd, I know, but my "broadband" is not broad, it's just isdn so there's no benefit to either buying wireless equipment for it or keeping the network cable run across my living room).
I'm hoping that the next sw release helps with this. Maybe I'll switch back to modem and try some of my own advice
