Hello I am looking to upgrade my current studio 20's v5 to a more transparent speaker with better detail, and air in the sound stage 3d imaging? Any recommendations? Willing to spend up to 3k
I might first suggest that you look at your rooms acoustics and speaker placement. 3D imaging will happen better the further from the wall you place the speakers allowing the space to get the depth, plus spreading them out a little will widen the soundstage. adding room acoustcs will help tame the room noise and should tighten up the sound.Quote:
Originally Posted by HeffeMusic /t/1521644/more-transparent-detail-air-speaker-than-my-paradigm-studio-20s-v5#post_24457511
