Well after deciding i would definatley go with the 'Antec fusion max remote' i thought id better measure up and make sure it would fit in my stand, and basically, it wont! Im not happy at all as i only bought the stand last month and it cost me about £100!
Anyways i need some suggestions please, it can not be any bigger the 480mm(W) x 390mm(D) x 190mm(H).
The depth is really the most important, it cant be more then 390mm (D).
Ive seen a case by 'Origen' - http://www.origenae.co.kr/en/htpc_s14v.htm -
Any one got one of these or know's what they're like? Are they quiet etc etc etc?
It has to be able to fit the 'Gigabyte - GA-MA790XT-UD4P' - http://www.gigabyte.com.tw/Products/...A-MA790XT-UD4P and it has to have at least 3 x 3.5" HDD bays and 1 x 5.2" drive bay, a remote and 3 or 4 slots
Or...
Can someone please tell me how good this microATX motherboard is please -
Asus P5QL-VM EPU Socket LGA775 Motherboard - http://www.misco.co.uk/applications/...nents-_-162379
Thanks in advance guy's as i know you've helped alot so far with my other threads.
Or...
