I forgot to mention - must be micro-ATX form factor!
Brian
Brian
Originally posted by olyar15 I have ordered both a new AGP riser card and a PCIE riser card which will hopefully work with the case. I am expecting it to be delivered any day now, and will let you know how it works. |
Originally posted by Brian Steele I've found two boards that might fit the bill, both available from NewEgg: 1. FOXCONN "760GXK8MB-ERS" SiS 760GX Chipset Motherboard For AMD Athlon 64 Socket 754 CPU 2. FOXCONN "865M01-G-6ELS" i865G Chipset Motherboard for Intel Socket 478 CPU Both have onboard headers for 4 USB ports and 1 FireWire port, to match the LC11's front panel. However, the AMD board also has an audio I/O header while the the Intel board does not, which gives it a slight edge as the LC11 also has audio connectors on its front panel. Which one of these would you consider to be the better choice, and why? |
Originally posted by LYU370 Which PCIe riser did you get, was it by chance this one? http://www.mypccase.com/2uriw2x32and.html Just wondering. Andy |
