Hi,
I have one of Comcast's DCX3400 DVRs, and using their remote control you can turn the power on/off no prob.
When I use the Nevo app on Android (VTAB 1008 tablet, with IR blaster), everything works fine EXCEPT the power on/off buttons.
I've set up Nevo using both the Comcast and Motorola device profiles...same problem. All other controls work fine, but not power on/off.
What's weird is that during the device setup in the Nevo "wizard", the power control works perfectly there. Just not after the setup is completed...
Ideas??
Ideas??
