Mount for Epson PowerLite S3?
303 Views 1 Reply 2 Participants Last post by  louthewiz
eBay has two dif't auctions at the moment:
search criteria - 'epson powerlite S3 mount'
but both are by "Mighty Mounts" (1st ones are auctions, 2nd list is his store)
Is that my best bet, should I go with a universal mount, or is there a better alternative? Thanks.
eBay search for 'universal projector mount'
(P.S. Why can't I link to eBay auctions? Afraid of people hawking their own stuff?)
Status
Not open for further replies.
1 - 2 of 2 Posts
For an epson mount I would go with the epson brand to assure a proper fit,but if you plan to upgreade in the future then get an omni mount at
http://www.bigscreencenter.com/mount_projector.asp
so then if you need to return it at least you can do so.
1 - 2 of 2 Posts
Status
