Mount for Panasonic GT50
1636 Views 4 Replies 3 Participants Last post by  Majcric
I am planning on getting a GT50 and it doesn’t come with the pedestal so I need to mount it and it has vesa pattern of 500x300 and it’s hard to find a mount that supports that. Does anyone know of a mount that works for this tv (60in). Also I need to have a base in the mount as wall mounting is not preferred.
1 - 5 of 5 Posts
I am planning on getting a GT50 and it doesn’t come with the pedestal so I need to mount it and it has vesa pattern of 500x300 and it’s hard to find a mount that supports that.....Also I need to have a base in the mount as wall mounting is not preferred.
If you're talking about a table top Pedestal Base (and not a credenza with upright mounting) then these two look like they would work.
The mounting brackets are height-adjustable as well as the main center post, and the VESA pattern goes up to 600mm wide.
Non-Swivel version:
https://www.amazon.com/Universal-Ta...48915011&rnid=1248913011&s=home-garden&sr=1-6
Swivel version:
https://www.amazon.com/Universal-Ad...se+for+TV&qid=1566170961&s=home-garden&sr=1-8
I have a smaller version of the Swivel model on a 49" TV and it's solid. The height adjustability of the center post and brackets enabled me to lower the TV far enough to get the bottom edge an inch above the glass base and it looks factory like that.
See less See more
Non-Swivel version:
Swivel version:
That seems like it states 500x300 but then in this screen it is not listed
Electronics Technology Electronic device Electronic component
See less See more
A
I'd noticed that too, but another picture shows up to 600mm, and 600mm is also mentioned in the description.
Maybe contact them for clarification, or post a 600mm question in the Amazon Q&A section.
See less See more
If you don’t mind paying a premium there is an OEM mount on eBay for a gt50 60”. I’m a stickler for originality but of course that would also depend on the condition of the TV.
1 - 5 of 5 Posts
