Status
Not open for further replies.
1 - 1 of 1 Posts
I need some suggestions on how I can mount my plasma above my fireplace. I attached a picture of what my wall looked like before the drywall went up. (note I didnt take the picture straight on).
The distance from the top of the mantel to the bottom of the outlet is 16 inches and I have that header below the outlet at a height of 11.5 inches. I know I'm going to use that header for the bottom mounting holes and probably the left and right studs which are right off center for the top holes.
I've come to the conclusion that a Chief PLP-2051 might fit this space but I also looked at the Sanus VMPL mount as well but putting that bracket all on the header will put the tv very close to the mantle not allowing me to go up much higher if I needed to. Anyone else have an idea? I thought about those toggler bolts people mention on here to go to drywall.
Mark
1 - 1 of 1 Posts
Status
