I live in a log home and all the exterior walls are solid logs. I want to mount an LCD in the 40-50" range to the wall. It seems like this should be fine.. but I can't find much info on it, and the one thing I did see had a short blurb saying it might not be a good idea.
"If you have a log cabin, walls with plaster over wooden or metal lathe, etc., this is not a good place to wall mount a HDTV."
newdimensionelectronics.net/wallmountflatpanel.aspx
Has anyone done this, or can anyone think of a reason why it would not be a good idea? Any other advice?
My other option is a stone masonry fireplace, but being natural stone it's not completely flush and I'd have to mount it slightly higher than I'd like.
Thanks for any advice.
