1 - 2 of 2 Posts
Hi there, I am working to ceiling mount an Optoma TH1060P projector and I am a little confused with regards to the height at which I should mount. Note that this projector does not have vertical lens shift. Should I mount it even with the top of the 92" screen or do I want it to be above the screen? If even with the top, is it okay if it's off by a couple inches?
1 - 2 of 2 Posts
