Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
I'm so excited with my 50phd7UY, but it's on the floor. My mount came today
http://www.peerlessindustries.com/fl...wall_smart.htm
My furniture came yesterday as did the plasma.
http://www.ethanallen.com/templates.../state_ent.html
After looking at the installation manual, I'm trying to decide how to mount the wall mount. Should I mount it anywhere on the wood back piece?
Or should I screw the mount through the wood and through the metal bars on the back
http://www.avsforum.com/avs-vb/attac...000&fullpage=1
As if I was mounting the plasma on metal studs.
I want to do this tonight, and of course do it right.
Thank you
· Registered
Hey gadget-
I'm not sure what I'm looking at in that picture, but I would definitely mount to studs of any sort, whether wood or metal. I have the exact same setup as you and haven't mounted mine yet either. :\\
1 - 3 of 3 Posts
Status
