841 - 860 of 930 Posts
If you want to see really fancy use of PGS subs as part of the video check out "You Don't Mess with the Zohan" (2008). They use PGS subs to show the HUD on a pair of night vision glasses. They load from the top of the screen about middle of the HUD. Only time I have seen PGS subs to do this.
Here are some others that I found:
  • The Mummy
  • The Mummy Returns
  • The Rundown
  • Dragon Wars
  • Paprika
  • The Professionals
  • Che Part 1 & 2
  • The International
  • Grand Torino
  • Defiance
  • Immortel
  • Hannibal Rising (only one caption)
  • Star Trek VI
  • Star Trek V
  • Star Trek III
  • Star Trek
  • Persepolis
  • Da Vinci Code
  • Mean Girls
  • Babylon A.D.
  • The Eye
  • Blindness
  • Dance With Wolves
  • Bangkok Dangerous
  • Pathfinder
  • The Legend of Zorro
  • The Mutant Chronicles
  • The Mummy Dragon Emperor
Thanks.:)
When you need to update the header info for a subtitle not playing which one do I edit.
Default track - no
Track enabled - blanked out unless I select add element
forced display - same as above
Do I just changed Default track -Yes ?
* I changed to Yes seems to work. What would the other 2 be used for.
Default track - no
I change mine to Forced = yes, Default = yes. Seems to do the trick.
Premium Member
The US BD of Everly has forced subs for Japanese spoken parts. It's a separate track and ClownBD doesn't pick it up at all.
Are you sure? They may be hardcoded. I'll find out for sure today.
They're not hard coded and they are not really forced subs. The first sub track is only the Spanish and Japanese subs.
MakeMKV 1.9.2 misses them as well, but Sub Track 5 is the correct track, and you're correct, it's not marked as a forced track.
I am hoping somebody can help me with the Iron Man and Avengers bluray. I am having 2 different problems. With Avengers I can not get the forced subtitles to work. I manually set the flag to forced using MKV merge. However the subtitles will not play using MPC-HC or Kodi. Am I missing something? Other MKVs play properly so I do not think its the players. With Iron Man the subtitles play for the scene in the caves but not later when the terrorists are in the village around the 1:16 mark. I am completely at a loss for that one. Any help would be appreciated.
Like you I doubt its the players - particularly as other files are rendering correctly. My guess would be that the rip hasn't pulled the subs correctly, perhaps something corrupt the process. I would try a re-rip of those particular titles.
I tried reripping iron man and still no luc. the track is there and it is tagged forced. MPC also identifies it as forced it just doesn't play properly. Are thrre any settings I am missing? I also set the track as default. Should I change this?
What programme are you using to rip?
I did that and everything seems correct. Also when I play the movie in both mpc and kodi the subtitles will appear if I enable that subtitle track so I think the track ripped correctly. However it seems the forced option is somehow not being applied properly.
