921 - 934 of 934 Posts
· Registered
Does it lock when some *else* is editing it?
I didn't think so as there are generally 70+ people logged into it. However, I can't be sure.
I do check it every 2-3 days to review the version history and this was the first time I've seen it in what appears to be a special view-only mode (no controls, no menu, tabs at the top).
Well, whatever the cause, it's back to normal now.
· Registered
Anyone else have Fast & Furious 6? Is the line at 1:47:55 supposed to have subtitles like the list says? My copy doesn't seem to have subs for that line.
I've checked around that time, and I found hardcoded subtitles at 1:44:55 (extended version). I've updated the sheet. If you can find an earlier time (ideally the 1st time), then please feel free to edit the sheet yourself.
· Registered
Yes. This is from my copy.
https://imgur.com/a/LwFlVgH
Thanks guys! I'll take a look when I get home.
Edit: Thanks to Plex I was able to check from work. The subs are indeed hardcoded for me at 1:44:55.
· Registered
If no one has one yet, I'd love a list that includes the movie title and the time or scene where the forced sub title occurs. That way I can test if my system is playing back forced subs properly. I finally figured out how to get plex to play them by modifying the flag on the subs with mkvtoolnix, now I just need a list and the scenes so I can test. A list with the movies isn't enough unless I want to skim through the entire movie trying to remember what scene has someone speaking in another language than english.
· Registered
For those that rip movies but like to include forced subtitles, I've started a database. This list will let you know before you start the process if you need to worry about Forced Subtitles or not.
Movie Subtitle
If anyone would like to assist me in adding to this database, let me know.
Sorry - I just noticed the first sheet was for movies without subs before I noticed the second sheet. This is an extremely helpful document! Thanks for posting!
I'm happy to give you a list of movies that do or don't as well so you can add to it - should we post here?
FIrst one - 6 underground - no english forced subs.
I have a lot more - not sure what is the best way to help.
· Registered
Movie Subtitles
Just wanted to thank you so much - I have many to go back and check but at least I have a place to start. I will add any others I come across.
