1 - 2 of 2 Posts
Ok guys im new to this. smelled something while playin ps3. went to see if it was the ps3 and i look inside where the fan is on the DVR and i see a flame!!! so ya its fried wont turn on.
My prob is i had some very important recordings on there. How would i go about getting them off since i cant turn it on at all. I have the hard drive out and slaved on my pc. What would i do from there?
motorola BMC9012F (broadband media center)
Put the drive back into the machine, take it back to your cable provider, and have them replace the unit.
Your recordings are gone. Unless you are an expert cryptologist and programmer, forget about retreiving the recordings-encrypted on the drive and uses an undocumented storage scheme. Good luck.
1 - 2 of 2 Posts
