1 - 4 of 4 Posts
Hi all,
Just installed mpc-hc 1.4.2499.0.
When I go into EVR Sync Settings, the options to Sync video to display are greyed out.
does anyone have any thoughts on how to make it so I can select the sync video options?
Discussion Starter · #3 ·
Nope, nothing is playing. This is happening on both machines I have it installed on.
both machines are windows 7. One 64bit (with 64bit mpc) and one 32bit (with 32bit mpc).
Discussion Starter · #4 ·
Just figured it out. On the playback --> Output option, EVR Sync must be selected.
1 - 4 of 4 Posts
