I'd like to convert my Replay MPEG streams to a compressed AVI format. DivX 5 seems to be the way to go. I tried out Dr. DivX, but its batch mode always crashes on me, and I don't like tying up my PC for long periods of time while it's encoding.
I figured I'd try to find a solution for conversion using my Linux box. Some Googling led me to a program called "transcode" which allegedly outputs DivX, XVid, etc. After many tests, I got a DivX encode to work, but the audio and video are hopelessly out of sync. I tried tweaking some of the sync options but nothing worked.
So is anyone out there using Linux to do Replay MPEG -> AVI conversion? If so, could you tell me what programs you're using, which codecs, settings, command-line parameters, etc.? I just can't get usable videos out of these utils.
