Multi-colored vertical lines on Plasma TV
4878 Views 4 Replies 5 Participants Last post by  hammerdwn
5
Hello, all. About a month ago we started noticing these strange vertical lines show up on our tv, sometimes they go away after a period of time, but are consistently visible when we first turn the tv on. anyone seen anything like this? i will attach some pictures for reference. first set of images shows solid lines that are colored depending on the content, the second set show how the colors of each set of lines shows up on the black background, and are dashed.
the lines are in groups of 5 or 6 and are blue, red, yellow and green scattered across the screen in no apparent order.
here is the tv model: http://www.lge.com/us/tv-audio-video...-tv-42PQ30.jsp
See less See more
1 - 5 of 5 Posts
wow, that's pretty wild. never seen that before. is it still under warranty?
That' normal, that's known as the jail house rock.
j/k That looks terrible, time to call in for TV repair specialist.
See less See more
iioeo,
a. are you using a set-top cable/sat box? if yes, how is it connected to the tv?
b. have you tried a dvd player on a different input? if yes, do you get the same lines?
Is the Tv menu/osd affected?
1 - 5 of 5 Posts
