I could swear I saw a neat 5-channel speaker cable assembly that I thought either came with or was made for either the Definitive SSA-50 or the Polk SurroundBar. It was pre-terminated with spade lugs, I believe.
Now that I want one, of course, I can't find it. ;(
I'm trying to minimize the wires on the back of my TV, since it is a thin one on an articulating arm. I'm planning on mounting an SSA-50 on top of the TV (have the Peerless bracket for it - on my mount and at the height that I have the mount, it works out best on top).
I'd like to stuff the bundle of HDMI cable from the receiver, Ethernet cable, and speaker cable(s) into one of those expandable fabric/mesh tubes (not sure what they are called). I'll run the AC line separately because the plug won't fit through and it's just not a good idea to bundle AC with low voltage...
Anyway, has anybody else seen this speaker wire assembly and able to refresh my memory? Obviously, I can just go to Fry's or plow through a Belden catalog and pick just about any old 10-conductor cable. (I assume for the short 10-foot run from the receiver to speaker 16-gauge is plenty?)
Of course, I'd like something super-flexy. Not so concerned about jacket protection, since I'll be adding my own (see above).
