Its not 4k compatible and looks like it cant run optical/coax/hdmi to zone 2
Hey there- For basement rec-room I'm looking for a 2 zone 5.1 or 7.1 receiver. For home theater use and more importantly for 2 channel audio (playing records and CDs.)
I have a line on a refurb NAD T748v2 for $399 that I'm seriously considering. I'll need to buy a $50 Rolls phono preamp with that as it has no dedicated phono input. That takes me to $450 which is about my max budget for the receiver. The feature-set on the NAD has pretty-much all I'd need.
Just wanted to check to see if anyone had any other suggestions or thoughts about it before I pulled the trigger.
thanks-
Jack
As much as I do want the NAD, I'm thinking that I need it to support 4K, so I may have to say nay on the NAD unless anyone knows of a good workaround.I currently have the NR1609 and have also had the NR 1603 and SR7008 and SR5012. The 1608/1609 will do really well for movies and music. No worries at all with the 50 watts, unless you're in a large room and plan on playing at high volume . That said, I would buy the NAD. I expect it would give better sound quality for music and movies.
4k workaround would be connect your sources by hdmi to your tv and run optical to the nad for audio. But then you'd have to change tv inputs and wouldn't get HD sound formats. Fairly inconvenientAs much as I do want the NAD, I'm thinking that I need it to support 4K, so I may have to say nay on the NAD unless anyone knows of a good workaround.
