Hi,
Trying to decide on a multi room. They all seem every similar to one another and with most have all sorts of control inputs rs232 and other options, it seems like they will work in conjunction with most other systems. With that, any suggestions on outright sound quality among the group? RTI, RUSS, Current Audio are just a couple. Any suggestions if one is after the best sounding. Application will be inwall and ceiling for bathrooms, bedrooms, kitchen, outdoors.
Thank you
Thank you
