Status
Not open for further replies.
1 - 1 of 1 Posts
Ok, here's the deal. I currently have an oval dish with 3 LNB's. I just added the Sat-C kit. The switch that came with the dish supports 4 receivers. I have 2 tivos using the 4 outputs. I have a Hughes HDTV receiver that will be here on Monday. What multi-switch do I need in order to add a couple more outputs. I would like to get 6 or 8 outputs for further growth.
My plan is to use one of the outputs from the 2nd tivo to run the HDTV receiver until I get this figured out.
Any help would be appreciated.
BE
1 - 1 of 1 Posts
Status
