Hi All! I need some help.
I am installing a CM4228 for OTA digital through a terk BMS58 multiswitch to my receiver (t160) and am having some issues.
The full setup is:
D* phase III dish -> Multiswitch (4 Sat inputs)
CM4228 -> CM 3401DBS amp -> amp power -> Multiswitch (OTA input)
at the receiver end I have a RCA diplexer which breaks out the antenna and satellite signals.
When OTA is not through the switch everything is fine. When through the switch I have no signal. I have tried DC blocks on each end (antenna & reciever), removed the amp, and even bought a terk diplexer to see if terk didn't work well with RCA, but no luck. When I diplex (can that be a verb?) at the antenna end and don't go through the multiswitch I get a signal, but any time I go through the switch there is no more signal.
Here are the combinations I have tried:
All I can think of is that I got a defective multiswitch. I can get a replacement, but I wanted to see if any of you gurus out there had any other recommendations.
Thanks for your time!
Ian Maki
The full setup is:
- CM4228 -> CM 3401DBS amp -> amp power -> Multiswitch (OTA input) -> diplexer -> receiver (no signal)
- CM4228 -> Multiswitch (OTA input) -> diplexer -> receiver (no signal)
- CM4228 -> Multiswitch (OTA input) -> dc block -> diplexer -> dc block -> receiver (no signal)
- CM4228 -> CM 3401DBS amp -> amp power -> dc block -> Multiswitch (OTA input) -> diplexer -> dc block -> receiver (no signal)
- CM4228 -> CM 3401DBS amp -> amp power -> diplexer -> diplexer -> receiver (sat and OTA are great)
Ian Maki
