1 - 4 of 4 Posts
Room Size : 15X20Ft
Living Room cum theater
See attached current wall and proposed design
Eqpt under consideration :
Screen
Draper 133" Diag 16:9 screen(already purchased and installed)
Speakers : (Not bought yet)
Option1 : Bose Acoustimass 10 5.1ch Series 4
Option2 : Definitive Tech Pro cinema 600/800
Option3 : Paradigm cinema 90/110 CT
Option4 : Energy classic 5.1
Option5 : Mix of speakers(posted
Budget for speakers 1000-1200$
See my post for speakers
http://http://www.avsforum.com/avs-v....php?t=1358817
Budget for Woodwork and PoP work : 2000$(see design)
Projector : Panasonic PTAE 7000u 3D Full HD( releasing in Sept 2011)
Not purchased - budget 3000$
AV reciever : Onkyo TXNR 609 (Budget 800-1000$)
Lighting for cieling, diffuse: Add another 500$
TV : Samsung/Sony LED 3D full HD, 46" (budget 2000$)
Construction to begin today..
I would cut budget on receiver to $300-$450 and take the extra and upgrade your speakers.
Originally Posted by vmanju123 /forum/post/20920671
Room Size : 15X20Ft
Screen
For all that is good and holy DO NOT BUY BOSE SPEAKERS!
The advise on adjusting your receiver budget is good, depending on what you need to do. Speakers are different than any other HT product as they will not be superseded like PJ's, receivers, and DVD players. Do your self a favor and also check out speaker manufacturers such as Axiom, Ascend, Aperion, and SVS as well. I would stay away from an actual "mix" of speakers as it is better to stay with the same manufacturer and "family" of speakers so they all play nicely together.
Good luck.
RTROSE
Why is the screen so high ?
Hurts my neck looking at it
1 - 4 of 4 Posts
