1 - 1 of 1 Posts
OK guys, I have a dedicated home theater and all my equipment is located in another room. I need a remote that will only be used in that room. Things to operate:
dvd player
satellite receiver 1
satellite receiver 2
audio receiver
this is it... I do not need anything fancy, and I don't mind using the learning mode to get the job done. I only want something that will not lose the memory or go threw batteries a lot. Low budget, just need to be able to get it to work without having to make like 20 trips into the other room to get something to play on my screen is all.
I have been looking on ebay and see I can get the mx-600 with emitters and base for about 100.00 or so. Or I can try to get the mx-800 for 150.00 or so (would like to spend the least possible).
HELP??
1 - 1 of 1 Posts
