I programmed my new MX-700 the last couple days but a few times I had trouble getting learned codes to work. It said "GOOD", meaning the remote picked up the signal, and the software showed that the button had learned (the blue L), but the device didn't respond to the command from the MX-700 (it would from the original remote). The remote in question is that of my Momitsu DVD-V880 DVD player. I "learned" two different buttons on the MX-700, twice, and it still didn't work - one being the center button of the big round button (1 inch in diameter), and the other the Enter button at the bottom. The code was the Enter key on the Momitsu. The 3rd time, it did work, at least for one button (the Enter button, not the big round button, which worked once, not the other). Have other people had similar problems?
In the MX-700 Editor, for System Information it says:
Firmware:
MX-700 Ver 1.98 / September 18, 2002
Universal Data:
Version 1.58 / September 27, 2003
Are there more recent firmware versions? Is the MX-700 firmware upgradable? Thanks for any info.
Firmware:
Universal Data:
