Got my mx-850 today. Most programming can be done by simply selecting from the IR Database.
The programming software is not bad. The IR Database is somewhat awkward to use when switching from one device to another. Testing, although a nice feature, requires your PC to be next to the AV equipment.
My issues are:
1. I programmed the remote to control the Sony STR-DE985 receiver by adding it from the IR Database audio section. Nothing happened.
2. There is no entry in the IR Database to control the IR543 "Infrared Command Center" (to control SmartHome LampLinc V2 plug-in light dimmers).
3. There is no entry in the IR Database to control the Panasonic PT-AE100U projector. I see a PL-AE900U, but no other similar choices.
Thanks in advance for any advice.
My issues are:
