1 - 3 of 3 Posts
Yesterday I picked up an Onkyo 504 receiver and worked on updating my MX700 remote. All is going well except after I learned the vol+ and vol- codes and tried it out on the receiver, if I press the button and hold it, it only changes the volume by one value.
So for instance, I can't press volume up and hold it and have the volume continue to raise. So to rock out I need to keep pressing the vol+ over and over. Not exactly cool. The Onkyo remote doesn't behave this way.
Does anyone have any ideas?
attached is my Denon file, it should help you, the naming might not be correct for you and you will need to rename some functions, but volume is fine.
denon.zip 4.513671875k . file
Discussion Starter · #3 ·
UPDATE: I found that the MX Editor for the MX850 works just fine with the MX700 and I was able to download the codes for the 504 using this setup, not only did I get some volume codes that work perfectly but I also got discrete power on and off!
1 - 3 of 3 Posts
