1 - 2 of 2 Posts
Discussion Starter #1
I am having difficulty in turning my HD1000U projector off with the MX810. I do not see it in the database which surprises me because that projector has been around for years. I tried several different models to see if they were similar with no luck so I learned the commands manually. The problem is that the power off button push needs to be repeated and it only responds as a single click.
I've also gone to tune up > Change power method for a component > selected my projector > Separate discrete on and off commands >Double click same button and it still will not double click the off button when selected.
Any ideas?
1 - 2 of 2 Posts
